Print at Sep 15, 2026, 7:55:47 AM
Posted by Keet at Jun 17, 2023, 3:13:16 PM
Re: Fix My Wonky Corners
Are you sure that is a screenshot from Sweethome3D? Because it looks quite different from my install. What gave it aways is the "Make invisible" in the context menu. You can't make walls invisible in Sweethome3D. I don't think there is any context menu in Sweethome3D with "Make invisible". So I assume that is a context menu from a different program.
I also don't see that two walls are selected.
For your corner you should select the two thick walls to join (top left and vertical). In Sweethome3D of course.
