Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Fix My Wonky Corners » » » » Post: Re: Fix My Wonky Corners |
Print at Sep 15, 2026, 7:55:45 AM |
| Posted by Keet at Jun 17, 2023, 12:55:41 PM |
Re: Fix My Wonky Corners Make sure you have selected the two walls you want to connect , then right click for the context menu which should have the option 'Join walls'. My guess is that you didn't have two walls selected before the right click. The two walls don't need to touch and can be some distance from each other. Sweethome3D will calculate the two nearest wall ends, extend the walls, and connect them into a corner. The walls don't need to be in a 90° angle. You can also connect walls to close a gap between walls. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 15, 2026, 7:55:45 AM |
