Print at Sep 14, 2026, 1:30:50 AM
Posted by drafthorse at Jun 17, 2023, 7:53:00 AM
Re: Wirings plugin
Hey, this plugins looks great but I've been unable to get it to work. I installed the Plugin Manager, and both Pan3DView and Wiring are up to date. Sweethome3D Version is 7.1.
The problem is that I can't pan the 3D View at all, and when I select the wiring tool, then clicks to the 3D view are not registered properly. It seems that the clicks are only registered in a tiny fraction of the top left corner of the 3D view, and even then the position of the node on the 3D view is unreliable.
I tried this on the i3 window manager, but to make sure that that's not the issue, I also tried on the cinnamon window manager, which is a bit more conservative... :)
Both tests were run on Arch Linux.
I think something is wrong here with the way the plugin handles clicks on the 3D view, but I'm not super sure. fwiw, I am able to select objects in the 3D view by clicking them, and all the other interactions, like rotate and zoom work fine. Even the accelerated zoom using the Shift key.
