Print at Sep 26, 2026, 12:42:27 PM
Posted by Keet at Jun 16, 2023, 9:44:08 PM
Re: Textures not importing
Some advise when you download from CGTrader: always download all formats available (obj, mtl, 3ds, dae, fbx, blend). In many cases importing a 3ds or dae model in Sweethome3D works better than importing the obj file. Also be aware that some models require downloading the textures in a separate file. You can see that in the list of available downloads.
You use the fbx file when all else fails: import it in Blender en export it as obj or 3ds. Then you can import the model in Sweethome3D. Sometimes it even works better to import first in Blender and export it to obj or 3ds. (Often the export to 3ds is more accurate then the obj export.)
You will probably have to learn some Blender anyway if you download more from 3D model sites: sometimes parts are shifted and you need Blender to fix those mistakes.
