Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Textures not importing » » » » Post: Re: Textures not importing |
Print at Sep 26, 2026, 12:41:29 PM |
| Posted by bashnprint at Jun 16, 2023, 8:12:58 PM |
Re: Textures not importing The section newmtl in the mtl file can contain a line starting with "map_Kd " followed by a path and file name to a texture image file. Usually there is no path and just a filename which indicate the texture images should be in the same folder as the obj and mtl file. Possible cause for not seeing a texture: the referenced texture image doesn't exist, is named differently, has an invalid image format, or has a wrong path. This was the solution! I managed to get the basic texture now loaded onto the model I was trying to import, thank you! Now just out of curiosity, the model I downloaded included 4 different texture files: a basic one (which is what I used), but also included a "cavity", "normals", and "occlusion" version. I assume these remaining 3 files are for other purposes and not for use here? |
Current timezone is GMT Sep 26, 2026, 12:41:29 PM |
