Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Lines and text to walls » » » » Post: Re: Lines and text to walls |
Print at Sep 15, 2026, 7:55:40 AM |
| Posted by Daniels118 at Jun 15, 2023, 10:48:08 AM |
Re: Lines and text to walls Just note that a texture applied to a wall will repeat for the whole height and length of the wall. Of course you can scale the texture to match the wall size, but this will also enlarge the drawing (also you can split the wall to apply the texture only to a segment, but this works only for lenght, not for height). Creating a texture the same size of the wall may be quite annoying, especially if you have to resize the wall because you have to resize the texture too. By applying the texture on a furniture (i.e. a box) you will decouple the image size from the wall size, giving much more freedom. You may optionally use a transparent background and export the texture as PNG to let see the background color of the wall. You may also consider using the Wirings plugin to rapidly prototyping the lines, but this will not work when rendering. |
Current timezone is GMT Sep 15, 2026, 7:55:40 AM |
