Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: sloping ceilings and light sources » » » » Post: Re: sloping ceilings and light sources |
Print at Aug 21, 2026, 3:16:46 AM |
| Posted by Puybaret at May 5, 2010, 10:01:55 AM |
Re: sloping ceilings and light sources I know the way the location of lights on sloping ceiling is computed isn't perfect and I should improve it. I suggest you to split your room in two joined rooms: one that will match the sloping ceiling and the other one matching the rest. The light at the ceiling of the second room should be ok in that case, if its middle is under the ceiling. You may also give a try to the advanced rendering plug-in that lets you place lights where you want. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 21, 2026, 3:16:46 AM |
