Print at Sep 13, 2026, 8:43:04 PM
Posted by db4tech at May 3, 2010, 9:08:39 PM
Re: Simulate sun position and lights/shadows
Hi Emmanuel,
I can't believe you've not have loads of replies about your new rendering plugin, it is incredible!! Maybe most people haven't noticed it yet? smile I'm new to Sweet Home 3D but for my first model I built a 2 floor building and this plug in has produced some fantastic lighting results!
Thank you also for your 3 extra lights. I have a request, would it be possible to give the lights a surface to make them visible in the '3D view' for easier positioning, I have carried out some tests and the candle lights (some of the only built in lights that work well) can be positioned then once in place can have their properties changed so the model is hidden, even when hidden this way it still produces a light source in the final advanced photo render.
    Is there any way to make large size lights (like a lighting softbox) so soft shadows can be generated? At the moment all shadows apart from the 'ceiling light' produce hard edge shadows (they still look great though compared to the normal in built lighting!)
    Also would you be able add an ambient lighting adjustment?
    Plus (this is an easier request) could you add a button to the Advanced photo window so a user can select either Landscape or Portrait for the rendered view? At the moment the only way is to switch off 'Apply proportions' and type in the portrait resolution information.
Thank you for this great plugin it makes Sweet Home 3D complete. It's so good that I'm surprised you didn't replace the normal rendering method and release it as 'Sweet Home 3D version 4'! smile
db4tech
