Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Convert to Autocad or DWG or DXF » » » » Post: Re: Convert to Autocad or DWG or DXF |
Print at Sep 6, 2026, 5:32:08 AM |
| Posted by Rolinger at May 16, 2023, 11:41:45 AM |
Re: Convert to Autocad or DWG or DXF I'll revive the thread since I have a specific workflow that produces extremely good results: In order to obtain an accurate cross-section or even a floor plan, the following steps must be taken: 1. Export the complete model in *.obj format 2. Import the model into Blender 3. Export the model in DAE format from Blender 4. Load the DAE model into Sketchup 5. Scale the model to obtain the appropriate scale of the model 6. Use Tools->Section plane and set the section plane to the appropriate position 7. Select "section plane" with the right button and select "Create group from section plane" 8. The group of elements created in this way can be moved to appropriate places outside the model and in this way more groups or cross sections can be made 9. Select the groups formed in this way and use the plugin "Export to dxf or dwg" I use SketchUp Make 2016 for this purpose and things work perfectly. However, I secretly hope that Puybaret will make a plugin that will enable this procedure directly in SH3D ;-) Best regards |
Current timezone is GMT Sep 6, 2026, 5:32:08 AM |
