Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: how to add column to a house » » » » Post: Re: how to add column to a house |
Print at Aug 25, 2026, 5:50:36 AM |
| Posted by michaelbr at Apr 17, 2023, 3:30:46 PM |
Re: how to add column to a house For a square column you can draw a square with walls in the size of the column and move it to the corner. Then lengthen/shorten the connecting walls so they touch the column. For a round column just use a resized cylinder. Everything was fine until I tried to connect the walls, because they have different thickness, when connected (they are connected using the middle of the wall), so the way SH3D does is I'll have excess thickness on both sides, is there a way to have it only to one side? (meaning one side of the wall is leveled/smooth, and the other side has an indentation of a thicker wall? I've attached an example to illustrate what I'm trying to express in words. https://flic.kr/p/2otWfDx ---------------------------------------- Thanks for your comment/suggestion Michael |
Current timezone is GMT Aug 25, 2026, 5:50:36 AM |
