Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Staircase generator plug-in » » » » Post: Re: Staircase generator plug-in |
Print at Oct 5, 2026, 6:45:50 PM |
| Posted by Keet at Mar 13, 2023, 7:09:29 PM |
Re: Staircase generator plug-in As some other plug-ins may use this way of doing and you don’t want it, you could try to set the user.name property to another value with the Java option -Duser.name=myname (this option can be set using the same way as the -Xmx option used to increase memory and explained in the FAQ). That works! (Although I'm still of the opinion that it's a serious security leak that should not have been introduced in the first place.)This should fix this way of doing that you consider as a security leak. I also found a second way around this which might be usefull for other users: Use the furniture library editor for every single object you create where you can set the creator name for each object. Once you add furniture in your plan that is imported through a furniture library the name is used as set in the library. This also allowes to use multiple different creator names if you wish to do so. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 5, 2026, 6:45:50 PM |
