Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Staircase generator plug-in » » » » Post: Re: Staircase generator plug-in |
Print at Oct 5, 2026, 4:55:34 PM |
| Posted by Puybaret at Mar 13, 2023, 5:09:54 PM |
Re: Staircase generator plug-in As some other plug-ins may use this way of doing and you don’t want it, you could try to set the user.name property to another value with the Java option -Duser.name=myname (this option can be set using the same way as the -Xmx option used to increase memory and explained in the FAQ). This should fix this way of doing that you consider as a security leak. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 5, 2026, 4:55:34 PM |
