Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Generate roof plugin » » » » Post: Re: Generate roof plugin |
Print at Sep 21, 2026, 8:17:01 AM |
| Posted by Keet at Mar 13, 2023, 2:56:10 PM |
Re: Generate roof plugin ...but the window is still vertical... Your window is probably still typed "Door or window" which means you can't tilt the window.Set the depth of the window to the thickness of the roof you created. Export the window and re-import it but don't check the 'Door or Window' property. You now have your window back which you can tilt but it won't create a hole in a wall. No problem since you want to insert it into the roof, not a wall. You will have to tilt the window to the same degree as you have the sloping of your roof part where the window is to be placed and you will have to set the position and elevation to fit it right into the hole in the roof. If the window had options for deformation ('opening the window') this will be preserved and should still work, even when tilted. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 21, 2026, 8:17:01 AM |
