Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Deploying SweetHome3D, to be embeded in webpage. » » » » Post: Re: Deploying SweetHome3D, to be embeded in webpage. |
Print at Oct 9, 2026, 3:58:52 AM |
| Posted by Puybaret at Apr 26, 2010, 6:17:11 PM |
Re: Deploying SweetHome3D, to be embeded in webpage. Sweet Home 3D applet can be built from source code available at http://sourceforge.net/projects/sweethome3d/files/SweetHome3D-source using the Ant "applet" target. This target builds jar files in deploy/lib directory, and the applet can be run with the HTML script deploy/SweetHome3DApplet.html. Depending on your needs you'll have to change the PHP scripts found in that directory to manage end user's home files. For more information, see the description of the parameters named writeHomeURL, readHomeURL, listHomesURL, writePreferencesURL and readPreferencesURL in the Javadoc of the SweetHome3DApplet class. As the applet comes with no furniture and textures, you should also read this subject to prepare the files describing furniture and textures listed in Sweet Home 3D applet. One last thing: don't forget Sweet Home 3D is distributed under GNU General Public License. If you plan to distribute a modified version of Sweet Home 3D, this license implies that you must distribute your program under the same GNU GPL license and make its source code available to anyone who requests it. Making the applet (modified or not) available on your web site is some kind of distribution, since it requires to users to download (automatically) Jar files. If this license doesn't satisfy you, please write to [email protected] to get information about the other available licenses that could meet your needs. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 9, 2026, 3:58:52 AM |
