Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Need Workshop 3D models » » » » Post: Re: Need Workshop 3D models |
Print at Aug 20, 2026, 12:58:55 PM |
| Posted by Art_in_MT at Feb 23, 2023, 1:38:39 PM |
Re: Need Workshop 3D models Thanks! I'm posting here in case others hit the same apparent dead end and miss the good stuff. I also did not find models at Trimble initially - but based upon your insistence I poked around. The search on the entry page runs against ALL categories (products, models, Collections, and Catalogs), but doesn't typically return woodworking tools. On the results screen, I had to change from searching PRODUCTS (the default) to searching MODELS. That is just a matter of clicking on the right heading. Not obvious if you've never been there before, but makes sense once you do, and you will find table saws, planers, jointers, etc. I found downloading in Collada format worked for importing into SweetHome3D. Thanks for the lead! Also, a direct link that skips the first (useless) search is : https://3dwarehouse.sketchup.com/search/?q=table%20saw&searchTab=model Thanks again! |
Current timezone is GMT Aug 20, 2026, 12:58:55 PM |
