Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 7.0 » » » » Post: Re: Sweet Home 3D 7.0 |
Print at Sep 23, 2026, 6:30:45 PM |
| Posted by YGYL at Feb 23, 2023, 8:28:48 AM |
Re: Sweet Home 3D 7.0 The lightSourceMaterialName# property was added to PluginFurnitureCatalog.properties of SH3F furniture libraries to define the material(s) of shapes which should be used in a 3D model as light sources at the two best quality rendering levels, for example to define a light panel or a ceiling mini spot with a thin light surface. Can you add a function to specify the brightness of this light-emitting material (recommended brightness). It can also be turned on or off by default. Avoid a light fixture made with this method, too bright or rendering too slow (crystal lights can be turned off directly) |
Current timezone is GMT Sep 23, 2026, 6:30:45 PM |
