Print at Sep 20, 2026, 6:22:23 AM
Posted by aminor00 at Feb 20, 2023, 7:20:28 PM
Re: Objets étranges en 3D
Thanks Emmanuel!
7.0.2i also works for me with my own files and the demos.
I did notice some small "stutters" and strange white shadowing effect in the 3D View but I discovered I had left the "Overdrive" setting on "Extreme" on my gaming monitor. When I switched Overdrive back to "Normal" the shadowing went away, and the stutters seem to be much less. 3D view now doesn't seem much different from when I had a 1080Ti.
HelonMead have you got a monitor with that feature? Can you set overdrive to "Normal" or "Off"?
Otherwise I suggest you try uninstalling the AMD Adrenalin drivers using the AMD Clean Up Utility (https://www.amd.com/en/support/kb/faq/gpu-601) then re-install the drivers. Does that help remove the stutters?
