Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: No 3d display in "modify openings" dialog » » » » Post: Re: No 3d display in "modify openings" dialog |
Print at Sep 29, 2026, 8:08:51 AM |
| Posted by Puybaret at Jan 18, 2023, 11:13:33 AM |
Re: No 3d display in "modify openings" dialog It looks like a driver problem and I fear it will be very difficult to help you on this. Maybe you could try to run Sweet Home 3D executable JAR with a more recent Java version, like Java 15 for example (with versions > 15, you'll have to add --add-opens=java.desktop/sun.awt=ALL-UNNAMED Java option in the command line). To run it with Java 3D 1.5.2, you'll have to use also -Dcom.eteks.sweethome3d.j3d.version=1.5.2 Java option in the command line: java -Dcom.eteks.sweethome3d.j3d.version=1.5.2 -jar path/to/SweetHome3D-7.0.2.jar---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 29, 2026, 8:08:51 AM |
