Print at Sep 26, 2026, 8:39:23 PM
Posted by Mike53 at Jan 17, 2023, 11:25:03 PM
Re: How to create a flat 3D shape/a flat plate, but with more than 4 corners?
The room tool is the right idea, create it on a level other than ground floor, that way you will be able to set and/or adjust its depth. You can freehand the room or use walls, set at maybe 2mm wide and 2mm high to draw the shape you require.
