Print at Sep 10, 2026, 12:39:53 AM
Posted by enkonyito at Jan 14, 2023, 6:24:06 PM
Re: Multi-photo rendering with different lights
Hi Roger,
Can you indicate here what you are having trouble with?
If you have the right to share the lights you use, you can attach a file containing them.
First information, the AutomateLightsRendering plug-in takes into account any object containing light sources whether they are integrated into the object or added manually.
On the other hand, the plug-in has not yet been updated to be compatible with the new version of Sweet Home 3D allowing to manage lights using the lightSourceMaterialName# property.
Second information, it seems that you are having the same problem cited by Mike Lee who uses the MacOS App Store version.
Not having a Mac, I could not test the problem and therefore try to solve it. Maybe Emmanuel Puybaret would have a solution.
EnkoNyito
