Print at Sep 27, 2026, 8:02:46 PM
Posted by hansmex at Jan 11, 2023, 1:49:11 PM
Re: 3D pictures rendering problem
Michael,
I had a look at your images.
The problem is that these models (probably) come from the Sketchup Warehouse. Some of these models cause problems for SH3D, when it cannot decide which side of a "face" (the triangles that build a model) it should show. Sometimes it shows the outside with texture, sometimes the inside without texture. That also explains why the result between two renders can be different.
The solution is to use Sketchup and give all faces of the model textures on the inside AND outside.
Or you could use another model, of course.
