Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Generate roof plugin » » » » Post: Re: Generate roof plugin |
Print at Sep 21, 2026, 7:52:23 AM |
| Posted by dorin at Dec 30, 2022, 7:12:45 PM |
Re: Generate roof plugin The GRT offer you the final version of Generate roof v.4.0 Next version (4.5 or 5.0) probably at the end of the next year. We already work on it in the limit of time and your interest. From CHANGE LOG: *add feature to compute holes in roof projection *add roof thickness *add specific property to roof piece of furniture *add option to set roof face invisibility before export *increase slope limit to 165 to cover entire range (180) *increase slope precision from 1 to 0.1 deg *increase number of selected faces to n-1 *add the reuse mechanism of the already generated roof ** now you could modify the roof including in new sessions ** implement an better way in generated levels *add few new elements to dialog I've not too much to say while Daniels118 have made all hard work: -The most important is the plugin became active if you select an room(s) OR select a previously created roof with this version. -Add an specific entry under the Help menu pointing to an help page. The help page or user manual or both are a work in progress. Also on Source Forge . ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 21, 2026, 7:52:23 AM |
