Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Pan tool in 3D and 2D view? » » » » Post: Re: Pan tool in 3D and 2D view? |
Print at Sep 14, 2026, 4:15:49 AM |
| Posted by sjb007 at Dec 23, 2022, 1:17:43 AM |
Re: Pan tool in 3D and 2D view? Some of my usual quick fire feedback. 1. When in Virtual visit mode and I use the visitor widgets in the plan to change the view (elevation, body/head angle) the black background returns. It's not too bad, as I just hit Ctrl-J twice to go out of parallel mode and back in and this fixes the rendering. 2. There is still a light grey block even when I set my floor and sky to pure white. If I understand what is happening, this is the camera front clipping plane cutting through the ground plane. I looked at the 3.7>3.7.2 code changes, but alas, I couldn't figure out if this was a colour you somehow chose to replace the black in your black background fix, or maybe some default UI/system background colour. Any chance to be able to set this as a preference? That way, we could get an all white background. Otherwise... The lines look way better now they can be thickened, although it would be nice to have the option to turn them off completely.Other crazy suggestions if you somehow figure a way to limit lines to edges where the angle of faces > x: A mode where all materials are replaced by plain white, for that outline sketch look. An architect I used produced some isometric sections in black line art. As I just thought about this, the silhouette would need to be forcibly outlined or it might go back to losing curved objects in the background again. I guess the rule would be if one face is toward the camera, and one faces away, then always draw the edge. Oh, and maybe it is time to reconsider the name of this plugin - it has become so much more than just panning. ![]() |
Current timezone is GMT Sep 14, 2026, 4:15:49 AM |
