Print at Sep 15, 2026, 5:25:55 AM
Posted by Keet at Dec 17, 2022, 10:24:30 AM
Re: higher stuff obscured by lower stuff
... I created what will be a physical wall inside the regular room walls (using several box objects for the various components) so that I could plan the placement of studs, plates, and sheetrock along one side of a staircase in my basement. In carpentry a plate is a 2x4 or larger length of wood that's laid horizontally on its side at the bottom and top of a wall. The vertical studs go between them and connect them...
You might be interested in the Dimensional Lumber library that offers lumber objects for that sort of construction.
