Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: What Is Magnetism » » » » Post: Re: What Is Magnetism |
Print at Sep 15, 2026, 3:57:30 AM |
| Posted by Keet at Dec 7, 2022, 10:33:54 PM |
Re: What Is Magnetism The most common occurance is where doors and windows slip into a wall and adjust themselves to the wall thickness. If you drag furniture against a wall it sticks and orientates against the wall so you don't have to manually fit it against the wall. Objects can also be dragged against each other and have a magnetism point where they 'stick' together, also for easy placement. Magnetism also causes furniture rotation and wall angles to occur in steps of 15°. If you switch magnetism off you can set any angle, place doors and windows without deforming into a wall, and move objects over each other without sticking against each other. This is all with mouse movement. When using the arrow keys magnetism is ignored. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 15, 2026, 3:57:30 AM |
