Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: higher stuff obscured by lower stuff » » » » Post: higher stuff obscured by lower stuff |
Print at Sep 15, 2026, 3:57:27 AM |
| Posted by DaveLab at Dec 7, 2022, 9:03:38 PM |
higher stuff obscured by lower stuffI have a beam going across the ceiling and a perpendicular wall's top plate that that intersects the beam, but at slightly below the top of the beam. Looks good in the 3D view. In the plan view the plate obscures the beam (even though the beam goes higher than the plate). I've tried changing the order of the objects in the list. I've tried copy/pasting the beam over itself. Nothing works. https://www.dropbox.com/s/vr27abhwvojxfhb/Sweet%20Home%20anomaly.JPG?dl=1 My best guess is that, because the beam's location reference (what is that point, the center of the "box"?) is slightly lower than the top plate's because the beam has a larger vertical dimension and extends well below the plate, the code thinks the plate is higher for the plan render (which would be a bug, I think). Thoughts? (sorry if this is old hat; I tried searching the forum and had no luck) ---------------------------------------- DaveLab Somewhere in western Massachusetts |
Current timezone is GMT Sep 15, 2026, 3:57:27 AM |
