Print at Sep 15, 2026, 4:48:44 AM
Posted by 3DMR at Nov 28, 2022, 5:31:27 PM
Regarding FurnitureLibraryEditor and TexturesLibraryEditor.
When I start FurnitureLibraryEditor or TexturesLibraryEditor they appear in a small window, when I load my Library I first have to adjust the size of the window (make it bigger) and then I also have to adjust all the columns so that I can read the - Name - Keywords - Category - Creator - Width - etc of the objects fully.
Sweet Home does not have this, when I start Sweet Home the window is also small, but when I set the size of the map window and the 3D window and create a new map and save it, and then close Sweet Home, and start Sweet Home the next day and load the newly created map, the window size set by me will automatically the way I set it up.
This is a very pleasant way of working, especially if you work with different floor plans!
My question;
It would be great if FurnitureLibraryEditor and TexturesLibraryEditor also saved the window size and column widths with the relevant Library.
Now every time I start a LibraryEditor and load my Library I have to adjust the window size and column width.
This is very frustrating, especially if you use the LibraryEditors a lot.
Hope a dedicated programmer can solve this frustrating "problem" soon.
