Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: camera back more and box on ceiling » » » » Post: Re: camera back more and box on ceiling |
Print at Sep 20, 2026, 7:24:33 AM |
| Posted by Keet at Nov 13, 2022, 9:10:24 AM |
Re: camera back more and box on ceiling it is not possible to make the hollow. It IS possible to make the hollow but it takes some work.
SH3D is not a true modelling tool, so you can't modify the mesh or do boolean subtractions. True, but you can get very far with what Sweethome3D does offer like making a hole as described. Even complex formed holes are possible by creating such a 'window'. You can also isolate a part of an object by making the other parts invisible and exporting/importing only the remaining part. That part can be used as part for other furniture you want to create.I rarely have to use Blender and when I do it's mostly to bisect an object or to remove pieces (vertices) of a object. One useful piece of advise if you are going to use Blender in combination with Sweethome3D: when you export an object from Sweethome3D to import in Blender make sure you first move it to the 0,0 position and elevation 0. This causes the object to be centered when you import it in Blender and you don't have to go hunt around where the object is. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 20, 2026, 7:24:33 AM |
