Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Parametrically defined or scripted home » » » » Post: Parametrically defined or scripted home |
Print at Aug 21, 2026, 1:31:02 PM |
| Posted by honzik at Nov 3, 2022, 2:54:22 PM |
Parametrically defined or scripted home Hello, first of all, thanks a lot for this amazing program! I would like to use SweetHome3D "parametrically". As a minimum example, assume a rectangular room surrounded by walls. I would like to have an option to resize the room based on given dimensions (width and height), without a need to redraw it manually. In reality, I would have many such rooms and walls, stacked together, dimensions of each room being independent parameter and I would like to define these parameters and see the result "easily" (without manual redrawing). In an extreme case, the home would be "scripted". Is it somehow possible currently? If no, I would create a Python tool for this kind of scripting, producing a XML file loadable by SweetHome3D. Would anybody be interested in such feature? Just if I should publish the code once it is eventually finished. Thanks Jan |
Current timezone is GMT Aug 21, 2026, 1:31:02 PM |
