Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Space under roof » » » » Post: Re: Space under roof |
Print at Sep 10, 2026, 2:33:20 AM |
| Posted by Keet at Oct 13, 2022, 4:43:04 PM |
Re: Space under roof I assume you have set the roof elevation to 0 and still have the gap. The easiest way is to have a separate level for the roof and adjust the elevation of the level so there's no gap. If you have an elevation > 0 for the roof you have to adjust that elevation. For the roof to fit on a sloping wall you have to adjust both the height and the angle. Changing one will also change the other so it's a matter of experimenting with both numbers to get it right. If you're close you can also adjust the wall slope a little to make it fit perfecty. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 10, 2026, 2:33:20 AM |
