Print at Sep 6, 2026, 8:00:32 AM
Posted by digitaltrails at Sep 25, 2022, 12:32:55 PM
Re: problem with use on linux
I just tried the code you sent and it kills the terminal!
It reads like you just entered the line in a terminal - which is not what I suggested.
To be clear about what should be done:
  • Find the executable script SweetHome3D. It will be a /bin/sh script.
    The command
    whereis SweetHome3D
    might find it, but it depends on how you installed it.
  • Save a copy somewhere, just in case something gets messed up.
  • Open this file with a text editor of your choice.
  • Find the line that starts SweetHome3D, it normally follows the comment "# Run Sweet Home 3D". It will be a very long line that invokes java and will look similar to the one I quoted, but perhaps not exactly the same.
  • Insert a new argument to java, that being
    -Dcom.eteks.sweethome3d.j3d.useOffScreen3DView=true
    - as illustrated in my previous post. Be careful to keep the line intact.
  • Save the file
  • Run the file
