Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Problem with the import of *.obj file » » » » Post: Re: Problem with the import of *.obj file |
Print at Oct 6, 2026, 12:54:31 AM |
| Posted by Puybaret at Aug 28, 2022, 10:07:14 AM |
Re: Problem with the import of *.obj file The MTL file must be in the same folder as the OBJ file or together in a ZIP file if you store the OBJ file, the MTL file and texture images in a zipped file. But this won’t probably resolve your issue, and if you want us to find the origin of the error, you’ll have to share the OBJ and MTL file. Maybe you could try to export your model in a DAE file which is also supported by Sweet Home 3D. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 6, 2026, 12:54:31 AM |
