Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Transparency value in color selector » » » » Post: Re: Transparency value in color selector |
Print at Sep 14, 2026, 12:48:15 AM |
| Posted by Daniels118 at Aug 25, 2022, 11:32:55 AM |
Re: Transparency value in color selector That would be very nice! However I have 2 workarounds for you: - you can use transparent textures to create transparent colors for furniture; it's a bit annoying because you have to create a different texture for each color/transparency level you need, but at least it works. - transparent textures doesn't work by default on walls in the 3D view, however there is a trick: just set a very small wall transparency in the 3D view settings, this way texture transparency gets enabled, and other walls will appear almost opaque. You can also shape the textures to obtain special cutouts (however the inner sides will be missing). The transparent textures works by default while rendering, so there is no need to change the wall transparency (moreover it is ignored). |
Current timezone is GMT Sep 14, 2026, 12:48:15 AM |
