Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Select Hide Utility plug-in » » » » Post: Re: Select Hide Utility plug-in |
Print at Sep 13, 2026, 2:20:48 PM |
| Posted by Puybaret at Aug 19, 2022, 5:26:39 PM |
Re: Select Hide Utility plug-in I just tested the last version and it doesn't work when there is no level in the home, with the following exception: Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException: Cannot invoke "com.eteks.sweethome3d.model.Level.isViewableAndVisible()" because the return value of "utility.SelectHidePlugin.access$6(utility.SelectHidePlugin)" is nullDorin, I hope this will help you to fix this bug. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 13, 2026, 2:20:48 PM |
