Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: double cut out for windows » » » » Post: double cut out for windows |
Print at Sep 24, 2026, 6:21:09 AM |
| Posted by flavio57 at Aug 17, 2022, 11:23:59 AM |
double cut out for windows Hello everybody, I want to insert a window on a thick wall with two different cuts on the inside of the wall and on the outside. suppose the windows are 100x140 cm wide, on the outside I want the opening with the same dimensions. instead on the inside of the wall I want a larger opening with an offset of xx cm all around, I want to indicate the depth of this large opening ------------------------------------------ | | -------------- | | ------------------------------------------ I managed to obtain the desired aesthetic result by creating two walls adhering to each other and inserting the window in the external wall and an opening without window in the internal wall but the solution is certainly not practical and has the defect that if I open the window it generates a unexpected cutout in the interior wall any suggestion ? is this the object of a new feature ? thank you in advance Flavio |
Current timezone is GMT Sep 24, 2026, 6:21:09 AM |
