Print at Sep 24, 2026, 8:56:12 AM
Posted by dkaparis at Aug 16, 2022, 5:32:15 PM
Error exporting SVG
Greetings,
Using Sweet Home 3D 7.0.2 under Archlinux and OpenJDK Runtime Environment (build 11.0.16+8). When I select the Plan->Export to SVG Format command and specify file, I get the following dump on terminal:
java.lang.NoClassDefFoundError: org/freehep/graphicsio/svg/SVGGraphics2D
at com.eteks.sweethome3d.swing.PlanComponent.exportToSVG(Unknown Source)
at com.eteks.sweethome3d.swing.PlanComponent.exportData(Unknown Source)
at com.eteks.sweethome3d.swing.MultipleLevelsPlanPanel.exportData(Unknown Source)
at com.eteks.sweethome3d.swing.HomePane.exportToSVG(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.HomeController$38.call(Unknown Source)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at com.eteks.sweethome3d.viewcontroller.ThreadedTaskController$1.run(Unknown Source)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:829)
Caused by: java.lang.ClassNotFoundException: org.freehep.graphicsio.svg.SVGGraphics2D
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:581)
at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:178)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:522)
... 13 more
The produced file is zero size.
Could this be a packaging issue? Any ideas how to diagnose further?
Thanks,
Dimitri
