Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Plug in RotateHome » » » » Post: Re: Plug in RotateHome |
Print at Sep 10, 2026, 12:35:39 AM |
| Posted by Keet at Aug 1, 2022, 9:37:42 PM |
Re: Plug in RotateHome I'm on Debian. I assume Ubuntu works mostly the same because it's based on Debian. From the plugins page: copy the SH3P file in the subfolder .eteks/sweethome3d/plugins of your user folder. The .eteks folder is hidden (because of the leading . in the name). To see it in your file manager you must first switch on Show Hidden Files from the menu. After that you can navigate to your "/home/<username>/.eteks/sweethome3d/ folder". If the folder plugins doesn't exist you must create it. Copy the RotateHomePlugin.sh3p file to the plugins folder. After restarting Sweethome3D you should see extra options to select and rotate in the menu. You can "install" other plugins in the same way: copy the SH3P file to the plugins folder. Recommended "must have" plugin: AdvancedEditing ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 10, 2026, 12:35:39 AM |
