Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Patch submission » » » » Post: Patch submission |
Print at Jul 22, 2026, 1:39:31 AM |
| Posted by nathanjshaffer at Aug 1, 2022, 4:14:12 PM |
Patch submission I'm not sure where is the best place to submit a patch. I have been working on a modification that I think will be useful. This program would benefit greatly from a constraint solver. This would allow for things like locking walls to a certain length/angle or having dimensions that are attached to walls and grow with the wall. To work towards this, I have made a pretty deep rewrite that does a couple things in this patch. 1. float arrays have been replaced by a Vector2D class. This allows for simpler code and puts a lot of the point math into a library. This will also be important for implementing a constraint solver as the algorithm should deal with points, not lines. 2. walls ends are connected to a wallpoint instead of directly to a wall. Moving a point, moves the connected walls. This allows more than 2 walls to be joined at a point. 3. I made the dimension help lines appear during dragging a wall. This helps with better placement based on wall length This patch allowed me to learn how the code was laid out and to simplify a lot of things.. I don't see an file upload, so I will just add it as a post. |
Current timezone is GMT Jul 22, 2026, 1:39:31 AM |
