Print at Sep 20, 2026, 3:18:00 PM
Posted by Keet at Jul 22, 2022, 8:39:35 AM
Re: Trouble installing Furniture Editor
and by the way, you should quit Sweet Home 3D if you want to edit the SH3F files used by the program.
I have used the editor on many occasions while SweetHome3D was also running and never had problems. Probably because the SH3F files I was editing were not imported yet in SweetHome3D.
Was this requirement mentioned anywhere?
A check and warning when you open a SH3F file which is already in use by SweetHome3D is a good feature for the next version because many users will not know this. That is, if it's safe to edit SH3F files not imported in SweetHome3D yet. Otherwise a warning that SweetHome3D must be closed is needed.
