Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 7.0 » » » » Post: Re: Sweet Home 3D 7.0 |
Print at Sep 23, 2026, 5:45:20 PM |
| Posted by Puybaret at Jul 19, 2022, 12:18:46 PM |
Re: Sweet Home 3D 7.0 @sjb007 The issue you report is not bound to 32 / 64 bit architecture, but is an effect of the bug I fixed about room drawing order. This ceiling should have been always visible to inform the user about the existence of its room just by seeing the plan. But even if half transparent, the gray used to draw such rooms might darkens too much the drawing and a lighter gray might be better as I suggested here. If needed, you may copy paste the room with its ceiling visible in a separated level that you won't view when exporting to SVG format. Rooms are always drawn before furniture in the plan where rooms / walls / furniture / polylines / dimension lines / texts / selection outlines are drawn in this order. The plan 2D view doesn't use any algorithm able to handle hidden faces like the 3D view is able. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 23, 2026, 5:45:20 PM |
