Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Round room: How to split walls for coloring? » » » » Post: Re: Round room: How to split walls for coloring? |
Print at Sep 20, 2026, 5:08:41 PM |
| Posted by Puybaret at Jul 16, 2022, 11:44:42 AM |
Re: Round room: How to split walls for coloring? You can create a round room without a copy paste operation, just keeping pressed the Ctrl key (alt key under macOS) while drawing walls. Pressing this key pressed will let you choose the angle after the click at the end of a wall. If you choose 180° for the first wall then go back towards its start you'll be able to draw a second round wall joining the first round wall. Then split the two round walls, change their arc extent to 90° and move the two ends which are at the wrongly place. If you remember that the diagonal of a square is 1.414 x its side length, you should be able to place them precisely. But, but... trying it myself, it seems that there are some bugs that I will have to fix! You should be able to achieve with the current version though. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 20, 2026, 5:08:41 PM |
