Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Round room: How to split walls for coloring? » » » » Post: Re: Round room: How to split walls for coloring? |
Print at Sep 20, 2026, 8:59:35 PM |
| Posted by Keet at Jul 16, 2022, 11:02:49 AM |
Re: Round room: How to split walls for coloring? how can I rotate a round wall (e.g. one with 90°) by exactly 90° in position, even that I can't manage. Are there no input fields for this? 2 ways: Select the wall and use the rotate icon on the button bar or press Ctrl+Shift+E to edit the wall properties. Bottom right you can set you 90° angle.To create your circle: copy, paste, and rotate the first part to get 4 parts and move them together. Zoom in as far as possible for greatest accuracy. The 3D View helps to see the match but if you look at the Start point and End point coordinates of each wall part you'll notice the relation between them and can set them to match exactly. If you do it right there are only a few different numbers used for the coordinates of the four parts. You should see the same number at several X or Y points. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 20, 2026, 8:59:35 PM |
