Print at Sep 6, 2026, 6:26:57 AM
Posted by Puybaret at Jun 27, 2022, 8:40:05 PM
Re: ScratchHome2 - need some help
You'll need two listeners:
- a first property change listener on home instance to follow the changes of camera (the property name is simply CAMERA)
- if the new camera is an instance of ObserverCamera (the class used for the virtual visitor), add a property change listener on the camera to follow the properties X Y Z.
Don't forget to remove the first listener when not needed to avoid memory leaks.
There's no SVG file for the virtual visitor. Its drawing is hard coded in PlanComponent class.
