Print at Oct 6, 2026, 7:45:14 AM
Posted by Daniels118 at Jun 6, 2022, 1:38:51 PM
Re: Soucis avec les éditeurs de bibliothèques de meubles et de textures
@captaincook
Which version of Java are you using running the tool?
You can check it by clicking at the last button on the toolbar (the one with the lamp icon).
For me, when using Java 11 the tool works properly, but as I switch to Java 8 I get the same exact behavior.
@Puybaret
I get the problem using the following OS/JVM:
Microsoft Windows [Versione 10.0.19044.1706]
java version "1.8.0_311"
Java(TM) SE Runtime Environment (build 1.8.0_311-b11)
Java HotSpot(TM) 64-Bit Server VM (build 25.311-b11, mixed mode)
The problem happens when repainting the table headers (but for some reason it only happens after the system open/save dialog is shown, doesn't matter if you hit confirm or cancel).
Here the first lines of the stacktrace:
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
at com.sun.java.swing.plaf.windows.WindowsTableHeaderUI$XPDefaultRenderer.paint(Unknown Source)
at javax.swing.CellRendererPane.paintComponent(Unknown Source)
at javax.swing.plaf.basic.BasicTableHeaderUI.paintCell(Unknown Source)
at javax.swing.plaf.basic.BasicTableHeaderUI.paint(Unknown Source)
at javax.swing.plaf.ComponentUI.update(Unknown Source)
