Print at Sep 24, 2026, 6:17:18 AM
Posted by thomasa88 at May 7, 2022, 12:52:42 PM
sad   Imported furnite icon renders as garbage
I have a problem that has been bugging me for some while in Sweet Home 3D.
Every time I import custom furniture from the web, the icon renders as garbage:
In the import Wizard, the rendering is fine:
Page 1:
Final page:
Imported bicycle. Garbage icon in furniture list and in 2D plan. 3D view renders fine.
I'm using Sweet Home 3D installed by the Ubuntu Linux package manager:
Ubuntu 22.04
Sweet Home 3D ® Version 6.6.2
OpenJDK version 11.0.15 - 64bit - 0.1 / 7.8 GB provided by Private Build Java 3D version 1.5.2 - NATIVE_OGL PDF print provided by iText SVG export provided by FreeHEP SVG path compilation provided by Batik Photo rendering provided by SunFlow
I have also checked a manually downloaded copy of Sweet Home 3D and I get the same result.
I have tried using both the Java binary supplied with the download and using my systems java (by changing the executable path to just "java").
./SweetHome3D-Java3D-1_5_2
exec "$PROGRAM_DIR"/runtime/bin/java -Xmx2g -classpath "$PROGRAM_DIR"/lib/SweetHome3D.jar:"$PROGRAM_DIR"/lib/Furniture.jar:"$PROGRAM_DIR"/lib/Textures.jar:"$PROGRAM_DIR"/lib/Examples.jar:"$PROGRAM_DIR"/lib/Help.jar:"$PROGRAM_DIR"/lib/batik-svgpathparser-1.7.jar:"$PROGRAM_DIR"/lib/jeksparser-calculator.jar:"$PROGRAM_DIR"/lib/iText-2.1.7.jar:"$PROGRAM_DIR"/lib/freehep-vectorgraphics-svg-2.1.1b.jar:"$PROGRAM_DIR"/lib/sunflow-0.07.3i.jar:"$PROGRAM_DIR"/lib/jmf.jar:"$PROGRAM_DIR"/lib/j3dcore.jar:"$PROGRAM_DIR"/lib/j3dutils.jar:"$PROGRAM_DIR"/lib/vecmath.jar:"$PROGRAM_DIR"/lib/jnlp.jar -Djava.library.path="$PROGRAM_DIR"/lib -Dcom.eteks.sweethome3d.applicationId=SweetHome3D#Installer com.eteks.sweethome3d.SweetHome3D -open "$1"
Sweet Home 3D ® Version 6.6a
OpenJDK version 11.0.15 - 64bit - 0.1 / 2 GB provided by Private Build Java 3D version 1.5.2 - NATIVE_OGL PDF print provided by iText SVG export provided by FreeHEP SVG path compilation provided by Batik Photo rendering provided by SunFlow
Any ideas? It seems to be some kind of problem storing the 2D rendering?
