Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Bug?: home plan doesn't update when plugin resizes furniture » » » » Post: Bug?: home plan doesn't update when plugin resizes furniture |
Print at Aug 21, 2026, 3:02:45 PM |
| Posted by adoberito at May 4, 2022, 2:46:34 AM |
Bug?: home plan doesn't update when plugin resizes furniture I've encountered what seems to be a bug, where when I have a plugin modify the size of a HomePieceOfFurniture, it correctly updates everywhere except in the home plan view. For example, if my plugin says: HomePieceOfFurniture projector = // ...The projector seems very stretched in the home 3D view, but appears as its default dimensions in the home plan view. If I then double-click it and go to the "Modify furniture" window, the correct (large) depth is visible. If I make some other change to the dimensions (for example changing the height), when I click "OK" the depth is now correct in the home plan view. --- If this is a bug, I assume you'll fix it in a later version. I'm using a version provided by Debian, so it'll probably be a long time for a fix. Is there some workaround I can use in the meantime to force the home plan view to recalculate the dimensions? Thanks! |
Current timezone is GMT Aug 21, 2026, 3:02:45 PM |
