Print at Oct 5, 2026, 9:17:09 PM
Posted by mirakels at Apr 14, 2022, 9:03:13 PM
Re: Wirings plugin
I played a bit with version 3 of the plugin.
I works reasonably good! A few remarks
- when I change the thickness of the polyline it does show the change in plan view, but not in 3D view.
- when I use the 'edit points' and delete or add a point from a wire (by accident or deliberate), I cannot add/change any wires in 3D-view anymore.
I guess that this last one is because 'edit points' degrades a wire to a normal polyline...
It would be great if Puybaret could work with you to integrate this plugins functionality into the main program (and hence support a height/elevation parameter for polyline points)!
That would also solve my issue as described in the wishlist forum ;)
Thanks for the good work Daniels118
