Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Problems with textures when rendering » » » » Post: Re: Problems with textures when rendering |
Print at Sep 29, 2026, 10:20:47 AM |
| Posted by Puybaret at Mar 27, 2022, 6:11:36 PM |
Re: Problems with textures when rendering You must have imported 3D models which are double-faced with different materials (i.e. front and back surfaces are defined using a different material for each surface). Making invisible their back face materials in the Material modification dialog box of these objects should fix your issue (generally, the material of the back faces can be quite easily guessed from their name and because selecting them in the materials list has no visual effect in the 3D preview). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 29, 2026, 10:20:47 AM |
