Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Installing Sweet Home 3D JS Online on my server » » » » Post: Re: Sweet Home 3D JS Online |
Print at Oct 14, 2026, 6:18:28 AM |
| Posted by kingoftailor at Mar 24, 2022, 11:24:02 AM |
Re: Sweet Home 3D JS Online I downloaded the sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4 There are SweetHome3D and SweetHome3DJS folders. I run ant at first o SweetHome3D. It creates the install folder with jar file. it is perfect. After this i run ant on SweetHome3DJS. I got 3 errors: [mkdir] Created dir: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\SweetHome3DJSweetExtension [javac] D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\build.xml:32: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds [javac] Compiling 4 source files to D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\SweetHome3DJSweetExtension [javac] warning: [options] bootstrap class path not set in conjunction with -source 8 [javac] 1 warning [mkdir] Created dir: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\ts [mkdir] Created dir: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\js [java] INFO: JSweet transpiler version 3.2.0-SNAPSHOT (build date: 2021-07-28 14:35:21) [java] 2022-03-24 10:44:19.019 INFO JSweetCommandLineLauncher:682 - input dirs: [..\SweetHome3D\src, tools\JSweet\src] [java] 2022-03-24 10:44:19.019 INFO JSweetCommandLineLauncher:694 - classpath: null [java] 2022-03-24 10:44:19.019 INFO JSweetCommandLineLauncher:709 - included: [def.*, com/eteks/sweethome3d/model.*, com/eteks/sweethome3d/tools.*, com/eteks/sweethome3d/viewcontroller.*, com/eteks/sweethome3d/io.*] [java] 2022-03-24 10:44:19.019 INFO JSweetCommandLineLauncher:710 - excluded: [] [java] 2022-03-24 10:44:19.019 INFO JSweetCommandLineLauncher:715 - add sources from directory: ..\SweetHome3D\src [java] 2022-03-24 10:44:20.020 INFO JSweetCommandLineLauncher:715 - add sources from directory: tools\JSweet\src [java] 2022-03-24 10:44:20.020 INFO JSweetCommandLineLauncher:760 - ts output dir: tools\JSweet\build\ts [java] 2022-03-24 10:44:20.020 INFO JSweetCommandLineLauncher:767 - js output dir: tools\JSweet\build\js [java] 2022-03-24 10:44:20.020 INFO JSweetTranspiler:423 - no configuration file found at D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\.\jsweetconfig.json [java] 2022-03-24 10:44:20.020 INFO JSweetTranspiler:528 - creating transpiler version 3.2.0-SNAPSHOT (build date: 2021-07-28 14:35:21) [java] 2022-03-24 10:44:20.020 INFO JSweetTranspiler:530 - current dir: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\. [java] 2022-03-24 10:44:20.020 INFO JSweetTranspiler:531 - base directory: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\. [java] 2022-03-24 10:44:20.020 INFO JSweetTranspiler:532 - working directory: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\jsweet.tmp [java] 2022-03-24 10:44:20.020 INFO JSweetTranspiler:533 - tsOut: tools\JSweet\build\ts - D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\ts [java] 2022-03-24 10:44:20.020 INFO JSweetTranspiler:534 - jsOut: tools\JSweet\build\ts - D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\ts [java] 2022-03-24 10:44:20.020 INFO JSweetTranspiler:535 - candyJsOut: tools\JSweet\build\js [java] 2022-03-24 10:44:20.020 INFO JSweetTranspiler:536 - factory: com.eteks.sweethome3d.jsweet.SweetHome3DJSweetFactory@4e04a765 [java] 2022-03-24 10:44:20.020 INFO CandyProcessor:123 - candies processor classpath: D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\.\jsweet_extension;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\jsweet-transpiler-3.2.0-SNAPSHOT-jar-with-dependencies.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\bigjs-3.1.0-20170726.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-awtgeom-1.8.132-20200519.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-batik-svgpathparser-1.10.0-20170726.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\j4ts-swingundo-1.8.132-20170726.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\lib\jsweet-core-6.3.1.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3DJS\tools\JSweet\build\SweetHome3DJSweetExtension;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3D\libtest\jnlp.jar;D:\SWEETHOME3D\sweethome3d-code-r8243-branches-develop-SweetHome3DJS-6.6.4\SweetHome3D\libtest\AppleJavaExtensions.jar [java] 2022-03-24 10:44:20.020 INFO CandyProcessor:141 - extracted candies directory: tools\JSweet\build\js [java] 2022-03-24 10:44:20.020 INFO JSweetCommandLineLauncher:891 - definition input dirs: [] [java] 2022-03-24 10:44:20.020 INFO JSweetTranspiler:561 - node version: 'node' is not recognized as an internal or external command, [java] 2022-03-24 10:44:20.020 ERROR ProcessUtil:466 - unexpected version token 'node' is not recognized as an internal or external command, / 4.4.0 [java] java.lang.NumberFormatException: For input string: "'node' is not recognized as an internal or external command," [java] at java.base/java.lang.NumberFormatException.forInputString(NumberFormatException.java:67) [java] at java.base/java.lang.Integer.parseInt(Integer.java:654) [java] at java.base/java.lang.Integer.parseInt(Integer.java:784) [java] at org.jsweet.transpiler.util.ProcessUtil.isVersionHighEnough(ProcessUtil.java:458) [java] at org.jsweet.transpiler.JSweetTranspiler.lambda$initNode$0(JSweetTranspiler.java:563) [java] at org.jsweet.transpiler.util.ProcessUtil$1.run(ProcessUtil.java:334) [java] at org.jsweet.transpiler.util.ProcessUtil.runCommand(ProcessUtil.java:361) [java] at org.jsweet.transpiler.util.ProcessUtil.runCommand(ProcessUtil.java:246) [java] at org.jsweet.transpiler.JSweetTranspiler.initNode(JSweetTranspiler.java:560) [java] at org.jsweet.transpiler.JSweetTranspiler.transpile(JSweetTranspiler.java:816) [java] at org.jsweet.JSweetCommandLineLauncher$JSweetTranspilationTask.run(JSweetCommandLineLauncher.java:897) [java] at org.jsweet.JSweetCommandLineLauncher.transpileWithArgs(JSweetCommandLineLauncher.java:272) [java] at org.jsweet.JSweetCommandLineLauncher.main(JSweetCommandLineLauncher.java:240) [java] 2022-03-24 10:44:20.020 INFO JSweetTranspiler:561 - node version: operable program or batch file. [java] 2022-03-24 10:44:20.020 ERROR ProcessUtil:466 - unexpected version token operable program or batch file. / 4.4.0 [java] java.lang.NumberFormatException: For input string: "operable program or batch file" [java] at java.base/java.lang.NumberFormatException.forInputString(NumberFormatException.java:67) [java] at java.base/java.lang.Integer.parseInt(Integer.java:668) [java] at java.base/java.lang.Integer.parseInt(Integer.java:784) [java] at org.jsweet.transpiler.util.ProcessUtil.isVersionHighEnough(ProcessUtil.java:458) [java] at org.jsweet.transpiler.JSweetTranspiler.lambda$initNode$0(JSweetTranspiler.java:563) [java] at org.jsweet.transpiler.util.ProcessUtil$1.run(ProcessUtil.java:334) [java] at org.jsweet.transpiler.util.ProcessUtil.runCommand(ProcessUtil.java:361) [java] at org.jsweet.transpiler.util.ProcessUtil.runCommand(ProcessUtil.java:246) [java] at org.jsweet.transpiler.JSweetTranspiler.initNode(JSweetTranspiler.java:560) [java] at org.jsweet.transpiler.JSweetTranspiler.transpile(JSweetTranspiler.java:816) [java] at org.jsweet.JSweetCommandLineLauncher$JSweetTranspilationTask.run(JSweetCommandLineLauncher.java:897) [java] at org.jsweet.JSweetCommandLineLauncher.transpileWithArgs(JSweetCommandLineLauncher.java:272) [java] at org.jsweet.JSweetCommandLineLauncher.main(JSweetCommandLineLauncher.java:240) [java] ERROR: cannot find Node.js: install first and make sure that the 'node' command is in your execution path [java] 2022-03-24 10:44:20.020 ERROR ProcessUtil:351 - cannot find node.js [java] java.lang.RuntimeException: cannot find node.js [java] at org.jsweet.transpiler.JSweetTranspiler.lambda$initNode$1(JSweetTranspiler.java:574) [java] at org.jsweet.transpiler.util.ProcessUtil$1.run(ProcessUtil.java:347) [java] at org.jsweet.transpiler.util.ProcessUtil.runCommand(ProcessUtil.java:361) [java] at org.jsweet.transpiler.util.ProcessUtil.runCommand(ProcessUtil.java:246) [java] at org.jsweet.transpiler.JSweetTranspiler.initNode(JSweetTranspiler.java:560) [java] at org.jsweet.transpiler.JSweetTranspiler.transpile(JSweetTranspiler.java:816) [java] at org.jsweet.JSweetCommandLineLauncher$JSweetTranspilationTask.run(JSweetCommandLineLauncher.java:897) [java] at org.jsweet.JSweetCommandLineLauncher.transpileWithArgs(JSweetCommandLineLauncher.java:272) [java] at org.jsweet.JSweetCommandLineLauncher.main(JSweetCommandLineLauncher.java:240) [java] ERROR: cannot find Node.js: install first and make sure that the 'node' command is in your execution path [java] 2022-03-24 10:44:20.020 ERROR ProcessUtil:365 - cannot find node.js [java] java.lang.RuntimeException: cannot find node.js [java] at org.jsweet.transpiler.JSweetTranspiler.lambda$initNode$1(JSweetTranspiler.java:574) [java] at org.jsweet.transpiler.util.ProcessUtil$1.run(ProcessUtil.java:353) [java] at org.jsweet.transpiler.util.ProcessUtil.runCommand(ProcessUtil.java:361) [java] at org.jsweet.transpiler.util.ProcessUtil.runCommand(ProcessUtil.java:246) [java] at org.jsweet.transpiler.JSweetTranspiler.initNode(JSweetTranspiler.java:560) [java] at org.jsweet.transpiler.JSweetTranspiler.transpile(JSweetTranspiler.java:816) [java] at org.jsweet.JSweetCommandLineLauncher$JSweetTranspilationTask.run(JSweetCommandLineLauncher.java:897) [java] at org.jsweet.JSweetCommandLineLauncher.transpileWithArgs(JSweetCommandLineLauncher.java:272) [java] at org.jsweet.JSweetCommandLineLauncher.main(JSweetCommandLineLauncher.java:240) [java] ERROR: cannot find Node.js: install first and make sure that the 'node' command is in your execution path [java] 2022-03-24 10:44:20.020 ERROR JSweetTranspiler:818 - cannot find node.js [java] java.lang.RuntimeException: cannot find node.js [java] at org.jsweet.transpiler.JSweetTranspiler.lambda$initNode$1(JSweetTranspiler.java:574) [java] at org.jsweet.transpiler.util.ProcessUtil.runCommand(ProcessUtil.java:367) [java] at org.jsweet.transpiler.util.ProcessUtil.runCommand(ProcessUtil.java:246) [java] at org.jsweet.transpiler.JSweetTranspiler.initNode(JSweetTranspiler.java:560) [java] at org.jsweet.transpiler.JSweetTranspiler.transpile(JSweetTranspiler.java:816) [java] at org.jsweet.JSweetCommandLineLauncher$JSweetTranspilationTask.run(JSweetCommandLineLauncher.java:897) [java] at org.jsweet.JSweetCommandLineLauncher.transpileWithArgs(JSweetCommandLineLauncher.java:272) [java] at org.jsweet.JSweetCommandLineLauncher.main(JSweetCommandLineLauncher.java:240) [java] INFO: transpilation failed with 3 error(s) and 0 warning(s) I use jre1.8.0_321 and jdk1.8.0_321 and apache-ant-1.10.12 |
Current timezone is GMT Oct 14, 2026, 6:18:28 AM |
