Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Generate roof plugin » » » » Post: Re: Generate roof plugin |
Print at Sep 24, 2026, 8:15:47 AM |
| Posted by dorin at Mar 20, 2022, 10:15:39 AM |
Re: Generate roof plugin New version 2.5 code-name "DL" Unfortunately this plugin left YAUP category and go to Normal Plugins. That happens when professional are implied. Thanks to Daniele who make 99% of work. For this I owed him a truckload of beer News: -bug fix in texture computation - @autor Daniele -elegant solution to correct faces name - @autor Daniele -remove blue edges when roof are exported - @autor Daniele -add a slider in place of spin box -replace "Refresh" button with "Reset all to 45dg" Now You don't need to set a rotation angle for texture, just select 1, few or all and set texture at once. Reminder of usage: -select a room (supposed to be roof footprint) -Tool-> Generate roof... -change angle as how You like -> OK -on 2D plan select object, Modify furniture, modify materials and set what texture you like. If You try to modify texture globally from first texture button will don't work as expected! Don't forget to set 3D view to show all levels. ![]() Also on Source Forge ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 24, 2026, 8:15:47 AM |
